Conduit module used up the pre-allocated conduit messagess.
Enable the log severity of HAL.Conduit to gather more data. If all the conduit messages are used, this error occurs. Check if Conduit raised an error. If an IOB is hot swapped but HAL has not detected the change, the error also can happen. Check if IOB is in the slot and operational.
Debug-Summary
Update of IO in slot %slot% failed with error-code %error% when a port %slot%:%port% is added to the VLAN instance %vlanInst%.
| Name | Type |
| slot | Slot |
| port | Port |
| vlanInst | uInt32 |
| error | sInt |
